93-96 Keyless Entry Module
Old May 28, 2014 | 06:43 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Hey All,
I have not been able to find anything about where to find the keyless entry module for the 93-95 firebird.
I know it is under the dash, will I need to take the complete dash out to get to it.
How much of the wiring harness should I be taking, I am going to put this in my 1989 Firebird?
Is there just the one control module
http://www.tacreationsusa.com/images...dule_small.JPG
or are there others.
Thanks for any assistance
Old May 28, 2014 | 09:43 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 93-96 Keyless Entry Module
You'll only need the relay that's pictured.....
Look behind the pass side kick panel and take as much of the wiring as you can reach easily. ( it's behind the kick in the Camaro and I'm guessing the Firebird is similar ) You'll need to add new wiring on anyway so the only wire you really need at the end of the plug is a 'pig-tail' that's long enough to solder - or splice - to.
Old May 28, 2014 | 11:10 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
this is news to me ! ...Whats needed to do this please! Tell me please
Old May 29, 2014 | 02:43 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
do a search for keyless entry
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
