alternator troubles none of the usual suspects
Old Jun 18, 2014 | 10:57 PM
KerberosCamaro's Avatar
Car: 1988 Chevrolet Camaro
Engine: 5.0L TBI (305ci)
1988 camaro sport coupe
5.0l v8 tbi
700r4
alt three wire plug
ran through the ENTIRE harness underhood twice.
ok so the car was charging just fine until a while ago it started to charge at about 13.1 instead of 13.7 as usual and now it runs at 12.7 if im lucky im getting too close to battery voltage and I haven't a clue as to why. the starter was replaced and i checked the connections all good looked at all of my fuses and the majority were ok i had to replace a couple but they were the acc fuse and the ecm fuse how it still worked is beyond me.on the fender and the gauge cluster fuse. for the longest time the cars volt meter in dash would bounce with the turn signals and such but now the things always at 12.7 and the battery is staying just charged enough to start and run but is fighting to live. all parts recently replaced new batt 5/15/14
starter 5/20/14. new alt 5/22/14 alt was bad. problem starts 6/1/14 problem escalates 6/6/14 problem goes away as checking for it while referencing the forums. fuses 6/17/14 now car is shored up on the driveway and i'm getting irritated chasing electrical gremlins. all of you here at Third Gen are awesome and i appreciate the time you guys give to help me and i wish i could be on more but my job makes it hard. any help is as usual greatly appreciated.
if you guys run into me at any time dont be afraid to ask for a beer ill happily oblige for all the help ive been given.
Old Jun 24, 2014 | 10:33 AM
Re: alternator troubles none of the usual suspects
wound up solving my own problems a reminder to all GROUNDS GROUNDS GROUNDS GROUNDS on a near thirty year old car check and recheck and then check again the GROUNDS.
Old Jul 2, 2014 | 12:34 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Elaborate for me. Which ground were shot
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
bjpotter
Oct 4, 2015 07:48 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
