how do i fix my speedometer ?
Old Jun 30, 2014 | 04:16 PM
reactz187's Avatar
i have a 92 camaro rs that had the 305 , it had the 350 swap done and now the speedometer doesnt work. how do i fix it without buying anything? it has the yellow box under the cluster.
Old Jun 30, 2014 | 05:02 PM
SansKey's Avatar
Former Sponsor
Re: how do i fix my speedometer ?
Hey. Does this thread help you out at all? https://www.thirdgen.org/forums/elec...92-camaro.html
Old Jun 30, 2014 | 05:51 PM
reactz187's Avatar
No it doesnt , thanks tho
Old Jul 1, 2014 | 10:56 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Need 4 Speedo Meter
Gain access to the buffer which looks like this:
It’s located behind the instrument panel at the right.
Connect an audio amplifier to terminal A
yellow wire to make sure it’s getting a steady signal.
Ground to ground, the signal wire to terminal A
yellow wire of the VSS.
With the car on jackstands listed for a hum from the amplifier when the rear wheels are rotating.
If you do, then find out if you get a hum from terminal C
tan wire.
The
tan wire then goes to the speedometer unit.
If it gets to the speedometer but the speedometer does not work, have it repaired or replace the unit.
Happy Racing !
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Aug 15, 2014 | 12:30 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Did the above work?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Elephantismo
Feb 13, 2019 12:51 AM
92firebirdguy
Sep 1, 2016 07:53 AM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
