EGR Solenoid Wire Woes
Old Aug 10, 2014 | 08:18 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
Evening,
Was in the middle of screwing down my EGR Solenoid wire connector into the EGR Valve of my 1986 IROC and the wire broke off the wire terminal. I have searched high and low for a replacement fitting with a wire length and can't find one.
I examined the fitting and carefully drilled down the center of the threaded post and was thinking about silver soldering it back in place.
Now if you don't know what fitting I am actually talking about, it's the nut type fitting that has the ceramic type tower and B-Nut type fitting plug. The pin literally threads into the tower.
Does anyone have this fitting with a length of wire? I would love to splice it in. Or any suggestions would be greatly appreciated. the fitting looks like heck and it's definitely showing it's age.
Old Aug 15, 2014 | 12:48 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Re: EGR Solenoid Wire Woes
Found one on e-bay. Should be here directly.
jklein337
Sep 19, 2018 06:23 PM
db057
Sep 4, 2015 07:57 AM
Out-Cast
Sep 3, 2015 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Accerrito22
Aug 23, 2015 07:22 PM
