'88 IROC Sporadic/Nonfunctioning gauges
Old Aug 16, 2014 | 07:34 PM
Mayt13's Avatar
Car: 1989 Chevy Camaro IROC Z28
Axle/Gears: Stock
Hi Guys,
My stock dash gauges really have me scratching my head; only the tachometer is working consistently and the oil pressure gauge intermittently. My coolant temperature is dramatically bouncing as though it has a poor connection. Even my speedo (although this is a mechanical connection IIRC) is completely not functioning.
I have checked (with a test light) all my fuses and they seem fine. I reconnected the speedo cable after I recently dropped the transmission (to solve an unrelated issue). I didn't see anything too complicated (just a square tipped wire fitting into a square hole).
Where can I find information on the location of the coolant temperature sensor and other gauge related sensors? I saw no such thing in my manual. Should I replace it or is it more likely an issue in the routing?
I don't have allot of experience trouble shooting wiring, I hear allot of people talking about "breaking out the multi meter". I have one, but I don't understand how to use it to track down the issue, or where to find normal current, voltage or resistance levels of components.
Any help is appreciated
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
