distributor problems
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: distributor problems
Assuming the 1991 distributor is from a V8, it will fit into the 1976 V8.
However, the electrical is not plug-and-play. Also, the 1991 distributor doesn't have any kind of advance mechanism (mechanical of vacuum).
There may also be an issue with the material the distributor drive gear is made from. I believe the gear is different for roller and flat tappet camshafts.
92camaroJoe
Aug 13, 2015 06:07 AM
