What is this connector for?
Old Jul 15, 2014 | 07:06 PM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
Transmission: THM 700 R4
Axle/Gears: 2.73 Stock
Based on the service manual, I am lead to believe this is the connector that goes to the AIR select valve solenoid.
Is this correct? The connector, as seen in the picture, is pink/blk and 2 brown wires on a 2 pin connector.
Attached Thumbnails What is this connector for?-picture-030.jpg   What is this connector for?-picture-031.jpg
Old Jul 16, 2014 | 08:18 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: What is this connector for?
EGR Solenoid by the distributer
Old Jul 16, 2014 | 08:24 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
I thought the black connector that looks similar is for the EGR solenoid? I was googling for the EGR solenoid pigtail, and found one with the notches in the correct orientation.
Old Jul 16, 2014 | 09:25 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
OK, this is what I found, only a 2 wire connector to AIR. Lot of searching. What side is that on; pass. or Drivers?
Old Jul 16, 2014 | 10:04 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
In this case, on my car, both are on the passenger side. In fact, both the plugs (based on the service manual) are mostly on the same circuits.
Is the pigtail you have pictured listed as an AIR select valve harness? If so, where did you find it? Been looking for days and found nothing that matches. I'd like to take a closer look to see if the notches are in the same locations.
Old Jul 16, 2014 | 10:13 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Try this site
[url]http://www.eficonnection.com
Old Jul 16, 2014 | 10:16 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
I am not sure that is the correct harness. My car is carbed, so the AIR system is different. Though I am not sure if the diverter valve is different from carbed to injected.
[EDIT]
I found the one I need on the same site. It's a different part number, but the picture shows the notches are the same. I am going to order and see what happens. That site never came up in all my searching.
Thanks.
Old Jul 16, 2014 | 10:36 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I dunno then
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
