Blank Aftermarket Gauge Cluster
Old Jul 22, 2014 | 03:56 PM
Zeifer's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
I've been searching for one, but can't find one that will suit my needs. At the very least I would like a drilled panel/gauge cluster with empty spots to put in some glowshift gauges. The problem I'm finding is I want one with the turn signal indicators and the high beam indicator.
If the warning lights were included that'd be great too because it'd be closer to factory, but no big deal if not.
Old Jul 23, 2014 | 01:39 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Blank Aftermarket Gauge Cluster
http://covansclassicdash.carshopinc....0df90861827c39
Drill your own holes for warning/indicator lights.
Old Jul 23, 2014 | 02:31 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I know you said aftermarket...but...???
Old Jul 23, 2014 | 07:36 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The only one available is that outrageously high priced classic dash piece for $170. That is what made me create my own gauge cluster:
https://www.thirdgen.org/forums/inte...i-made-my.html
Give it a read as it may answer some of your questions and give you ideas.
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 20, 2015 06:59 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
TrevinE
Sep 14, 2015 03:20 PM
