what to do with unused plugs/wires
Old Jul 30, 2014 | 08:06 PM
Gecz28's Avatar
Car: 88 iroc vert
im doing the ls1 swap and there is a bunch of wires in not going to use, abs, cruise ect, what can i do with them besides taking the whole harness apart. id like to just cut them off and tuck them back inside the harness but that would probably short something out??
any recommendations??
mike
Old Aug 1, 2014 | 07:00 PM
Pocket's Avatar
Car: 91 Trans Am
Re: what to do with unused plugs/wires
Trimming and tucking works, but please tag each before you do it. Also, please disassemble and rebuild the harness to meet your needs with the swap. Wiring is difficult enough. A crappy job will leave you with more headaches in the end
Old Aug 2, 2014 | 12:36 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
I never like leaving a bare end regardless of if the other end is hooked up or not. I'd cover the ends with electrical tape.before tucking.
Old Aug 2, 2014 | 01:05 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Unless your talking about the LS harness,
The 3rdgen cruise harness can be completely removed from the car.
Old Aug 4, 2014 | 07:02 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I always wrap with electrical tape as well before tucking, better safe than sorry.
Old Aug 4, 2014 | 09:33 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You can cut the wires at an offset (Ie. an 1" or so) so the two ends can't physically meet. Then fold the long end down and wrap in tape. That said, I've been able to tuck the wiring with connector ends into the wire loom but it takes some creativity of placement.
If you're installing an LSx harness I agree that it's best to rewire it properly as it could end up being a huge headache.
1992rs/ss
Jan 31, 2025 05:10 PM
CAMAROBEAV
European Region
Apr 29, 2021 04:54 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
armybyrd
Sep 23, 2015 06:17 AM
2MNYMaros
Sep 15, 2015 11:36 PM
