Driver Side Harness?? 92 Camaro??
Old Aug 8, 2014 | 09:16 AM
Drone358's Avatar
I was told that anything 90 and above just have the ECM harness and everything is all in one. But my car still has the driver side c207 connector and harness. I'm swapping from TBI to carb and don't need the ECM. Now i'm just flustered on what harness i need to get to run all my interior and headlights etc. Also with a T5 tranny??... any info is much appreciated!
Old Aug 8, 2014 | 12:01 PM
Drone358's Avatar
Re: Driver Side Harness?? 92 Camaro??
I've been reading, and seems maybe a V6 model camaro would work in my situation? Not sure...
Old Aug 8, 2014 | 01:31 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
From my experience with swapping my 92 from a V6 to a carb:
You need to keep the ECM so your speedo and odometer work
The drivers side connector in the engine bay contains all your front lights wiring in one half, and the wiring for your gauges, wipers, fuel pump, and cooling fans in the other. There are also some power wires and the starter wires in that same half you'll need to keep.
Most of the ECM wiring comes into the engine bay from the passenger side, and can be removed.
Be careful what you remove as your AC wiring, blower motor wiring, speedo, reverse lights, and some power wires are also in that harness.
Your cruise control won't work
You'll need to install a switch in one of the heads to turn your radiator fan on.
Old Aug 8, 2014 | 02:45 PM
Pocket's Avatar
Car: 91 Trans Am
Do a search for 3rd gen harness prep in the ls1 forum. That thread covers cutting down a stock harness to power and gauges, which is all a carb engine needs
You do not need the stock ECM to keep your gauges working
Tach is ran directly from the distributor
Coolant and oil are analog senders
Alt and fuel are independent of the engine harness
Speedo is unique for 90-92 cars. V6 and TPI cars need to have a buffer box added
TBI cars already have a buffer box, so leave the VSS wires alone and the speedo will work fine
89 and older cars all have a buffer box, so no worries
The only engine control system related to cruise is speed signal, which is part of the buffer box for TBI cars. V6/TPI cars need the 2000ppm wire ran from buffer box to cruise module
Connect the dk grn/wht wire from the fuel pump relay to 12v ign. Your TBI car will already have a low pressure pump installed, so if it works leave it alone
Scavenge the thermal switch from the pass cyl head for the fan relay
TBI Ac system is independent of the engine control, so just separate it when cutting down the engine harness
Old Aug 8, 2014 | 02:50 PM
Drone358's Avatar
Damn, ya thats alot i was worried about. I had a friend just cut pretty much every wire off the passenger side besides two wires ( don't remember what colors they were) probably red and black. I'm going to analog tach and speedometer so that should be ok. Just worried about the power and wiring the distributor.
Old Aug 8, 2014 | 04:04 PM
Drone358's Avatar
Sweet man, thanks for the Info! I'll check it all out, Awesome feedback!
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
