help no headlights, others work
Old Aug 8, 2014 | 02:32 PM
71-iroc-rs's Avatar
try by pass of fuseable link at starter. nothing ...... another post had no lights at all , was link I have 2 cars same thing no main lights both 91......... help
Old Aug 8, 2014 | 03:12 PM
Joe Tag's Avatar
Re: help no headlights, others work
You will best be able to test this with a multimeter. Poke the + probe through the insulation after the fusible links with - probe grounded. If you are certain the fusible link is good, get to the headlight switch. Test the red wire coming into the switch for 12v+. If you are certain the switch has 12v, turn it on and test the yellow coming out of the switch. If that checks out test the tan and light green coming out of the dimmer switch on low and high beam respectively. If those check out, move to the tan and light green wires at the lights. Post back your results.
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
