Intermittent power window problem
Old Aug 21, 2014 | 05:07 PM
Chuck's Avatar
The drivers side window on my 88 IROC works fine ... most of the time.
Often, though, it will not roll up. If I lightly press the up switch,
it will usually work.
Obvious switch problem?
Chuck
Old Aug 22, 2014 | 12:19 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Intermittent power window problem
Replace the switches with billet aluminum ones.
The left and right are the same part number so you could switch switches (sides) and see if the problem moves.
http://www.camarocentral.com/1984_19..._p/dwn-439.htm
Old Aug 22, 2014 | 03:41 AM
83ZZZ28's Avatar
Car: 1983 Z-28.. Owned since 1985
Engine: LG4 (H) Vin Code
The power window motors are notorious for working intermittently, then stop working all together.
In 29 years of owning my '83 Z-28, I have replaced a window motor on the avgerage of every 5 years. The heat in Phoenix eats them up. The same thing happens to all of my Third Gen friends in the Phoenix area.
I have replaced both of my window switches, not because they didn't work, but to keep the interior looking like new.
Good luck.
Rod
83ZZZ28
Old Aug 25, 2014 | 11:49 AM
Chuck's Avatar
Thank you very much!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
