fog light question
Old Aug 26, 2014 | 09:48 AM
TramsAmGuy36's Avatar
fog light question
I am wondering if there is a way to turn on the fog lights without the headlights on? if not is there a way to allow that to happen? I have an 88 Camaro iroc-z
Old Aug 26, 2014 | 09:51 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: fog light question
Yes. Simply rewire the lights so that they aren't tied into the headlights (as they currently are).
Old Aug 26, 2014 | 09:58 AM
ok so is there a way to rewire it using the factory switch to keep it looking as stock as possible?
Old Aug 26, 2014 | 11:14 AM
Car: 1983 Z28
Yes, if you disconnect all the wiring that goes TO the switch and replace it with a simple relay set up (not wired into the headlights) you can make it so that you can turn your lights on whenever the key is turned (whether the engine is running or not).
There's probably also a way to bypass the connection to the headlight switch in the current set up.
I'm not familiar with how the fog lights are wired in on these cars (mine does not have them). However I have installed off-road lights on many vehicles and the principles are the same.
Old Aug 26, 2014 | 04:21 PM
thank you I will see wat I can do and try to figure something out
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
