How do I remove the TPI wiring harness?
Old Aug 30, 2014 | 05:46 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hi Guys,
Just pulled my first engine and transmission yesterday and feeling pretty good about it!
I've got a guy coming to pick up the motor and tpi system today and need to remove the tpi harness and ecu.
I know it's going to be connected to other stuff so I just need to know what wires I need to cut and where they are/go?
Had a search on the forums but can't find anything on this, any help would be greatly appreciated!
It's an 85 TransAM with 165ECU with auto trans.
Old Aug 30, 2014 | 06:44 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: How do I remove the TPI wiring harness?
If you are just going to cut wires, cut them all and don't look back.
If you need to save ANY of the wiring harness, unplug every connector you can find... Well, everything off the engine and trans. If there is something still connected, follow it, and unplug it. Repeat until the harness comes off.
Old Aug 30, 2014 | 07:08 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Pocket wrote a great article on this, read through it.
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Old Aug 30, 2014 | 08:24 PM
evilstuie's Avatar
Thanks guys,
I found this one here on the forums:
https://www.thirdgen.org/forums/engi...g-harness.html
And it gave me enough info to get it out, only had to cut 2 wires, the rest all came out from unplugging connectors which was good.
Probably the only good job of wiring done in the car after all the RHD conversion wiring chaos I've found.
Engine trans and harness are all out of the car, soon comes the SBC400 AFR1040 HSR combo monster to break my transmission and diff to create new problems LOL
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
