battery relocation, alternator not charging
Old Sep 12, 2014 | 08:00 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
relocated my battery to trunk now alternator not charging enough. i'm getting 12v al the alternator with engine running. the battery is new fully charged and I get 12.7v at the battery itself. alternator itself tests good so I wonder if my wiring is wrong.
heres the wiring
2 g welding cable from battery to taylor cuttoff switch
2 g welding cable from switch to starter
4 g cable from switch to alternator
2 g battery ground to frame/ 4g ground strap to pass cylinder head and frame to front of engine
accessories connected to starter.
by the way I'm running an electric water pump set up running a march pulley system, with a march 1.75 pulley on the alternator. any ideas where I went wrong?
Old Sep 19, 2014 | 07:36 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: battery relocation, alternator not charging
probably not the issue but, 0/2ga would be better from rear to front.
grngryoutmyway
Oct 18, 2016 05:48 PM
customblackbird
Oct 1, 2015 04:30 PM
Johnoooooo
Sep 22, 2015 08:55 AM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
