Starter enable relay....NEED HELP
Old Sep 22, 2014 | 08:23 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
1991 RS 305 tbi. Car will not start. Bypassed the starter enable relay (jumped the two thick wires) and the car will crank with the key but will not start. I bought a new relay and get nothing. What to look at next? Thanks
Old Sep 22, 2014 | 09:01 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Starter enable relay....NEED HELP
Sounds like you possibly need to either fix or disable/bypass your VATS system. Did you have injector pulse when you bypassed the relay? VATS shuts down injector pulse and starter operation.
Old Sep 22, 2014 | 09:36 PM
Car: 1991 Camaro RS
How can I tell if there is a pulse when cranking?
Old Sep 22, 2014 | 10:08 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Just jumping and un jumping the starter enable relay will tell you if its VATS.
Jump it and it has cranks.
Un jump it using the relay and it does not crank.
= VATS is active and trying/is shutting you down.
There used to be a member here that could burn you a new EPROM but that's does not seem available at this time.
Start with a simple key bypass using resisters with the wires under the dash/column.
Link = https://www.thirdgen.org/vats
Old Sep 23, 2014 | 04:29 AM
Car: 1991 Camaro RS
This may be the problem....I'll look into it. Thanks
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
