fan comes on with car off
Old Oct 9, 2014 | 06:13 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Ok guys, so i've had this happen twice now. I'll take my lunch break and go sit in my car, i turn it on (not start it) and listen to the radio. The engine is cold as its been sitting about 4 hours. After about 10 to 15 minutes the fan comes on. The only thing i can think of is resistance in the temp sensor causeing it to get hot and turn on the fan. Does this sound right or has anyone else ever heard of somethin like this?
Old Oct 10, 2014 | 11:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: fan comes on with car off
You can check the wiring for the intake coolant temp sensor and the power switching wire (will be a ground) for the relay. You can try replacing the coolant sensor as they are cheap anyway. Something is tripping the relay it is either the switching wire (ground) grounding out between the relay and ecm or a bad ground from the sensor to ecm or a bad sensor.
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
Leggman1
Aug 6, 2015 04:15 AM
