Electric windows not working, everything else works
Car: 1984 camaro Z28 H.O
Engine: 5.0 H.O
Hey everyone, I have a quick question for y'all. Two ago I was hooking up a electrical fan to my car, and I know I'm supposed to hook it up to the pink under dash wire, we'll it was my first time and I think I hooked it up to maybe the window wire? Reason being everything worked in the car literally, and then when I hooked it up at first one in line fuse I had connected busted, then I replaced the fuse inside and it still doesn't work, I have the original book that came with it, and I looked under at the fuses which powers the locks,hatch and it's good but doesn't light up and only half light up with a test light and the others don't. I would think the power locks and hatch wouldn't work to if its a fuse but those work and not the windows, and also the radio fuse doesn't light up with a test light, but the radio still works
Engine: 5.0 H.O
Re: Electric windows not working, everything else works
Okay sooooo I have power going to the motor and switch. Is the motor gone out if I'm getting power to everywhere else?
db057
Aug 11, 2015 10:11 PM
