Intellitronix dash
Old Oct 20, 2014 | 09:04 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Intellitronix dash
Pick up a intellitronix digital dash for 100.00 bucks, it came with all senders except oil, but works with stock.
Easy install, wired right up and looks great, also went with the intellitronix GPS speedo 3 wires and done
Chris
Old Oct 26, 2014 | 06:54 AM
G_FORCE32's Avatar
Re: Intellitronix dash
I INBOXED U BUD. WOULD LIKE TO SEE HOW IT LOOKS.
Old Oct 26, 2014 | 07:29 AM
Rus Boelter's Avatar
I'm having some issues with my 91 firebird with the 3.1L. She runs for 10-15 seconds then dies. I can start the car right back up afterwards and same thing.. dies. I have replaced the fuel pump and filter and was also told to replace the crank sensor which It does not have. just wondering if you could point me in the right direction here? I was also told it could be a camshaft position sensor. Which the auto parts stores does not even list. Just need help. Thanks in advance
Old Oct 26, 2014 | 05:26 PM
Car: 1988 iroc
Engine: 350 30 over
Just hooked it up temporally till I solder the connection to the back of the old white plastic gauge cluster.
Video clip
l
Old Nov 28, 2014 | 08:08 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
what do u have to solder? and did it come with the pinout for what to solder? thnx
Old Nov 29, 2014 | 07:45 PM
Car: 1988 iroc
Engine: 350 30 over
https://www.thirdgen.org/forums/atta...instrument.gif
This to follow the wiring the gauge location to the plastic and copper embedded board the soldered to the correctl locations the board also make sure you run a independent from the intellitronix gauges to the engine block also be careful soldering to that board it's only plastic with a thin copper
Old Nov 29, 2014 | 09:01 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
is that the schematic for the original cluster or the intellitronix?? it doesn't show the wires coming from the tronix pcb and what color is for what... thnx again...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
