vats resistor wiring help
Old Nov 27, 2014 | 10:57 AM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Found the 2 white wires have resistors jus need to know what wires to solder it too or how it goes... thanks any help appreciated
Old Nov 27, 2014 | 01:36 PM
GaryDoug's Avatar
Car: 98 Trans Am
Transmission: A4
Re: vats resistor wiring help
Unplug the connector and attach each end of the resistor to each terminal for white wires. The chosen resistor must match the key's resistor.
Old Nov 27, 2014 | 07:17 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
So I unplug it drop in the resistors an plug it back in???
Old Nov 27, 2014 | 08:20 PM
GaryDoug's Avatar
Car: 98 Trans Am
Transmission: A4
No, don't plug it back in and don't just "drop them" in. See this topic:
https://www.thirdgen.org/forums/elec...able-vats.html
Search with "VATS" on this web site and you will find a zillion topics about this.
See these also (later year but it is the same for a 3rd gen):
http://shbox.com/1/pass_key.html
http://shbox.com/1/4th_gen_tech2.html#pass_key
http://shbox.com/1/vats_bypass.jpg
Old Nov 27, 2014 | 08:28 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Ok cool thanks for the help!!!
Old Nov 27, 2014 | 08:38 PM
GaryDoug's Avatar
Car: 98 Trans Am
Transmission: A4
I made a temporary emergency one for my 98 that I keep in the tool bag. In a 3rd gen it is a "VATS" module instead of a "BCM". Other than that, it's the same. First photo shows the resistors that are combined to make the needed resistance. If you bought a kit of 15, you probably only need one resistor. The second photo shows the same, but cleaned up with a cover over the resistors. For permanent use, a better connection will be required.
Attached Thumbnails vats resistor wiring help-vats-bypass-trial.jpg   vats resistor wiring help-vats-bypass-temporary-installation.jpg
Old Nov 27, 2014 | 08:40 PM
pimprs's Avatar
Engine: 3.1
Axle/Gears: stock
Yeah I figured it out but tomorrow ima finish up everything right...thanks for the help I really apreciate it!!
stalkier
Dec 6, 2015 11:25 PM
armybyrd
Dec 5, 2015 09:22 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
