alternator help
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: alternator help
V6 and V8 alternator should be rated the same. It should work fine as long as you're swapping over all your stuff. Now if you change the belt type (serpentine vs v belt) then you will have issues.
Car: 1988 Camaro
Re: alternator help
You don't mention years, but in most cases no the V6 and V6 alts will not interchange due to the mounting points.
The V8 alt. has the mounting ears 180* (or straight across) from each other, where the 2.8L and 3.1L V6 used in these cars alt has the mounting ears at something like 90* apart
raymondandretti
Sep 27, 2015 06:43 PM
