1989 Turbo Trans Am Wiring Issue
Old Dec 4, 2014 | 11:54 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Hello, I am having a no start issue. When I attempt to start the vehicle it just makes a clicking noise out of the relay shown which is attached at the firewall on the drivers side. I have replaced starter and fuel pump, and tested alternator and battery. There was an extra wire attached on the back of the alternator which runs to the relay shown. When I attempted to plug the wire back in, it made a loud thunderous crackling noise coming from the starter/flywheel area almost as if the car was attempting to crank. This is without the key in the ignition. My guess is the wiring from the starter is run to this relay? Any input would be greatly appreciated, thanks.
Old Dec 5, 2014 | 12:25 AM
Re: 1989 Turbo Trans Am Wiring Issue
I know when I replaced the starter I did not use shims, could this cause a no crank issue?
eightsixseven
Dec 16, 2024 01:50 PM
camaro11j
Sep 19, 2018 08:49 AM
armybyrd
Dec 5, 2015 09:22 AM
kyleb24
Aug 15, 2015 08:24 AM
stalkier
Aug 7, 2015 04:49 AM
