turn signal only hazards
Old Dec 31, 2014 | 10:15 AM
patriots781's Avatar
Car: firebird 91
Engine: 350 5.7 small block
Transmission: turbo transmission
So i have a 91 firebird and my turn signals stopped working, but when i hit the hazards they all work, everytime i try to put a fuse in it blows as soon as i touch the turn signal switch ,i tried the flasher idk what else could it be please any input???
Old Jan 2, 2015 | 07:16 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turn Around
Unplug the turn signal flasher.
After removing the flasher the TURN-B/U fuse still blows, check the backup lamps route.
However if after removing the flasher the TURN-B/U fuse does not blow, your problem is not in the backup lamps route.
Therefore if removing the turn signal flasher stops the TURN-B/U fuse from blowing, turn the key to OFF, install a good TURN-B/U fuse, unplug the longer of the two flattish connectors located on the right side of the steering column.
Now, if the TURN-B/U fuse no longer blows your problem is in the steering column.
Happy Racing !
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Old Jan 3, 2015 | 09:48 AM
Car: firebird 91
Re: turn signal only hazards
can someone tell me what the fuses or wires hooked up in the circled area?
Old Jan 3, 2015 | 11:18 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
seems like that would be the relay area for fans or lights?
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
