Hazard flasher v Turn signal flasher
Old Jan 14, 2015 | 02:46 PM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
I have searched for quite some time and cannot come up with a concrete answer to a couple of questions I have.
I am going to be switching my rear bulbs to LED when I install my STS kit in a few weeks. I already know I need to have an LED flasher installed otherwise the LEDs will not function properly.
Last year I changed out what I thought was my turn signal flasher but apparently ended up being my hazard light flasher.
The question I have is, where are the two flashers located and are they exactly the same part? The flashed I changed out was in the convenience center and had two prongs on it. Where is the turn signal flasher and does it look the same?
Pictures and links will make me extra happy. I've seen some people give links to three prong flashers, others to two prong flashers. I've got an 89 GTA if it makes any difference.
Old Jan 14, 2015 | 03:49 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Hazard flasher v Turn signal flasher
Here is a pic of led flashers on a 91 bird
Old Jan 14, 2015 | 04:02 PM
Car: 89 GTA
Engine: 5.7 TPI L98
Thank you! Are they both the same part? Ex: same number of prongs?
Old Jan 14, 2015 | 04:17 PM
thomas1976's Avatar
Car: 91 Trans am
Yes the same, 2 prongs. The LED flasher I found/used have an extra ground wire.
Old Jan 14, 2015 | 04:34 PM
Car: 89 GTA
Engine: 5.7 TPI L98
Thank you for the help. All the threads I looked at and I couldn't figure it out. The picture makes it super clear!
Any chance on a part number? Lol
Old Jan 14, 2015 | 04:52 PM
thomas1976's Avatar
Car: 91 Trans am
If you type "led flasher 2 pin" on ebay you will find the exact same ones I have used in the pic http://www.ebay.com/itm/2-PIN-PRONG-TERMINAL-RELAY-ELECTRONIC-FLASHER-12-VOLT-LED-TURN-SIGNAL-LIGHT-/231025309223?pt=Motors_Car_Truck_Parts_Accessories&hash=item35ca2e7627&vxp=mtr
This may be fun too https://www.thirdgen.org/forums/elec...ml#post5708048
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
