90 iroc won't start or do anything
Hey guys I'm having a starting problem see my iroc is my DD and me and my gf were on the way to look at prom dresses for me senior prom and when we left it cranked up no trouble ran perfectly fine the whole way there no spits or spats or anything when we get there I pulled up put in park and turned it off we got out and walked no more than 10 feet found out they were closed -.- so we go back to the car and try and crank it.... Nothing... I instantly thought "VATS is acting up" so I tried it again no security light but I still have it the five minutes and tried again nothing.... It wouldn't click, try to spin over, nothing just silence... So I called my dad he's a big car wizard and he said it sounded like the starter so we got it home and after much monkeying around, cussing, and farting XD, we got it out and hooked at battery up to it and used a screwdriver to test it to see if the starter is locked up.. It's not the starter flywheel shot and spun and everything... So then we thought well must be battery nothing else it could be so we tested it... 12 volts so my dad said it could be a slew of things at this point unfortunatly as I said before it's my DD and I miss my baby 😟😟😢😢 so many mustangs have gone unembarrassed since it's been broke down and I wanted to get a few other expert opinions on the matter just to see if I could speed things up so thanks for reading my long *** post guys I really apreciate it and all the help thanks
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 90 iroc won't start or do anything
Please put your car info on the left like mien. It's located on the "User CP".
That said, when you opened the door, do you get interior lights or anything?
1st thing I would check is all the f uses. Then I would check all wiring down at the starter making sure it's tight, especially if when you open the doors you get no lights or anything. If the wires at the starter are tight and you have no interior lights or power to the inside of the car, I would suspect the fuseable link coming up from the starter has blown.
mustangman65_79
Aug 11, 2015 03:17 PM
