wiring harness
Old Jan 28, 2015 | 10:57 PM
T-rock's Avatar
Car: 1987 camaro iroc
Transmission: 5 speed borg warner
Axle/Gears: 3.45
wiring harness
Does anyone know what these wires are for and where they go.There is a couple of black ones ,one of them is frayed which I think are ground wires,a pink one and some connectors.Thanks T-rock
Attached Thumbnails wiring harness-img_20150127_190227.jpg   wiring harness-img_20150127_190242.jpg   wiring harness-img_20150127_190332.jpg   wiring harness-img_20150127_190256.jpg
Old Jan 29, 2015 | 03:23 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: wiring harness
Can you follow the wires and see where they end up? That might help.
Old Jan 29, 2015 | 03:24 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: wiring harness
Also, what year and model is your car. See where it says "car, Engine, Transmission" on the left of my post? Please put your info in there as well. It's found under the "user CP" tab. Just hover your curser over your screen name in the upper right and you'll see "user cp".
Old Jan 29, 2015 | 08:25 PM
T-rock's Avatar
Axle/Gears: 3.45
Re: wiring harness
OK it is a 1987 camaro iroc that came with a 305 Tpi 5 speed car,has a 350 in it now.Hard for me to trace the wires right now but they go into another sleeve that goes behind the distributor.here are a few pics.I will have a better look on the weekend.
Attached Thumbnails wiring harness-img_20150129_194032.jpg   wiring harness-img_20150129_193951.jpg
Old Jan 29, 2015 | 10:09 PM
Pocket's Avatar
Car: 91 Trans Am
Re: wiring harness
Looks like the HVAC power wire with the branch adapters
Pop the zip tie and stretch it out. It should be fed by a single 12ga red wire that has an inline connector
Old Jan 31, 2015 | 01:50 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: wiring harness
One looks like a hood light power wire
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
armybyrd
Dec 5, 2015 09:22 AM
stalkier
Aug 21, 2015 01:54 AM
