Engine won't crank - Possibly VATS?
Old Jan 30, 2015 | 04:34 PM
PeterFeix's Avatar
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
Hi there,
my 1989 GTA has now been converted to the Holley HP EFI System, so the old ECM is gone.
Some hours ago I tried to crank the engine but nothing happened - No security light, just the handbrake-light which turned off once
Current situation:
The C207 connector is not plugged in since I think there is nothing left to be wired there any longer.
I haven't done the VATS bypass yet, since I still have the factory key which worked well in the past, at least in combination with my old '165 ecm.
Did anyone had the same issues? Maybe with converting to carb or ls1 swaps etc?
Hope someone can help me!
Thanks in advance
Alex
Edit:
Found the schematics of the vats system and edited and updated it to my current setup:
[IMG][/IMG]
Old Jan 30, 2015 | 10:24 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Engine won't crank - Possibly VATS?
Join the two heavy gauge wires of starter enable relay together (bypass the relay)?
https://www.thirdgen.org/forums/ltx-...formation.html
post#20 C207
Off the top of my head, I was thinking that the service engine light was activated through 207 pin c, but some one else can correct me, I'm not to familiar with 89'.
Old Jan 31, 2015 | 07:06 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
post#20 C207
Jumper the A and E terminals together at the starter enable relay. With your setup, you will then have completely bypassed the VATS system.
Old Feb 1, 2015 | 04:27 PM
PeterFeix's Avatar
Both wires are joined now, but unfortunately the battery drained over night so no chance to test if it worked.
Hope for tomorrow
Old Feb 6, 2015 | 01:39 PM
PeterFeix's Avatar
Hi again.
At the moment I don't have any spark.
Have 12v on pink cable which goes to the coil, coil is grounded properly.
Wires are all new MSDs ; Distributor is about 2 years old MSD Pro Billet which ran fine last time I drove the car (2years ago). Could I have killed the ICM when I accidently connected my starter wires with reversed polarity?
Old Feb 7, 2015 | 08:16 AM
Lurbie's Avatar
Car: 89 Camaro
Reverse polarity can certainly damage some sensitive electronics if they aren't internally built with protection against that. However... Can you elaborate on what was connected reverse polarity? Everything at the starter motor is a positive voltage, the starter gets its ground from being bolted to the block.
I am not yet familiar with MSD's trigger system to fire the coil, maybe someone else with some MSD knowledge can jump into this thread to help out as well?
Old Feb 7, 2015 | 12:13 PM
PeterFeix's Avatar
Sorry, if I wasn't precise enough.
I just made that mistake directly at the starter. Put the starter field wire where the 12v from battery had to go and vice versa. That drained my battery to death. At this time everything else was connected properly.
On monday I'll get a spare distributor to check if something went bad in there. Btw I just have the MSD direct replacement for the stock distributor, so nothing special.
Old Feb 7, 2015 | 10:35 PM
Car: 91 z28
Transmission: 4L60e
5.7
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
msd list this as stock replacement (5.7)
http://www.msdperformance.com/product.aspx?id=5365
Old Feb 10, 2015 | 01:09 PM
PeterFeix's Avatar
Hi all !
Swapped the ICM which was faulty. It was a PITA cause MSD doesn't use connectors, the wires were just soldered and shrinkwrapped onto the pins of the ICM. That was really not what I expected from MSD.
Anyway: Had a little struggle with starting the engine, some misfires, most likely it wants less spark advance at cranking, had it at ~10-11° btdc. Seems that it wants less.
Old May 29, 2015 | 02:02 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Hey there,
I bought a new VATS Key for my 92 RS 3.1L and it worked for 36 hours. After changing a few fuses, and checking the rest I tried the ignition and VATS appears to be killing me. I've tried cleaning the key, i've tried cleaning the inside of the lock cylinder, still nothing. The ONLY thing that happens is the instrument panel lights up (No Security Light). No noise from the starter, no action in the fuel pump... HELP PLEASE!!!!!
Old May 29, 2015 | 03:48 PM
Lurbie's Avatar
Car: 89 Camaro
VATS does not disable the fuel pump. You have another problem. You can either choose to diagnose your no crank condition or the lack of fuel pump operation, it is likely that either will lead to the cause of both.
Why were you changing fuses? What else is wrong with the car?
Old May 29, 2015 | 07:58 PM
Engine: 305 / 350
@Lurbie - The power hatch wouldn't operate, the ACC 20A Fuse was blown. Replaced it, checked others while at it. When I Re-Inserted the ECM Fuse and tried the ignition...nothing. Today I actually found that the continuous VATS issues I was having despite the New Key was the VATS wires where they connect at the Lock Cylinder. I did the ever so popular "Bypass" w/ Resistors from RadioShack and Thank GOD the engine cranked! VATS Issue solved for $1.50 and some electric tape lol. Now i'm impatiently waiting on morning for my mechanic to install my new fuel pump and replace 2 transmission lines and I should finally be on the road
Old May 29, 2015 | 09:49 PM
Lurbie's Avatar
Car: 89 Camaro
Awesome! I'm glad you found it so quickly.
Caspar
Jun 19, 2016 11:19 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
