painless wiring harness in 89 iroc
Old Feb 3, 2015 | 09:31 PM
1stiroc's Avatar
I have a 89 iroc that needed a new harness. I put a painless harness in it for map sensor. Everything kicks on but no spark. I was wondering if anyone else had this issue when they put this harness in. Someone said I need the esm hooked up but the painless harness doesn't have a spot for the esm. I checked all the connections and they are good and power going to it.
Old Feb 23, 2015 | 06:32 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: painless wiring harness in 89 iroc
What engine and injection?
Old Feb 23, 2015 | 06:35 AM
1stiroc's Avatar
I figured it out, ignition module. Now it's dumping way to much fuel. I'm gonna replace fuel pressure regulator, and get mem cal for a 305 5 speed. The mem cal in it is for a 5.7 auto.
Old Feb 24, 2015 | 04:34 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Did you have any other problems with it? I put one in mine with the MAF system. The ECM is only sending 5v to the fuel pump relay (green wire). If I jump the relay it kicks on the pump, seems like the ECM isn't sending the correct voltage.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
armybyrd
Dec 5, 2015 09:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
