What is the best MAF sensor replacement?
Old Feb 14, 2015 | 10:32 AM
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
I have searched and search everyone's horror stories trying to find a replacement for their MAF sensor. So my question is this, What is the best brand to buy as a replacement?
Old Feb 14, 2015 | 10:47 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What is the best MAF sensor replacement?
A used Bosch !
Old Feb 14, 2015 | 10:49 AM
mackjar66's Avatar
Car: 1989 GTA
Why a used one?
Old Feb 14, 2015 | 10:55 AM
brett89's Avatar
Car: 1989 Trans Am GTA
On average how many Miles can you expect to get out of the factory maf ?
Old Feb 14, 2015 | 11:09 AM
mackjar66's Avatar
Car: 1989 GTA
No clue I'm build my TPI now and if the MAF craps out for whatever reason I don't want to be stuck and I don't want to swap over to SD
Old Feb 14, 2015 | 11:57 AM
Engine: Lb9
Transmission: M20
Originally Posted by mackjar66
Why a used one?
Because new Bosch ones are $300 plus. Stay away from microtech, granatli , cardone.
You can use other vehicle production mafs but unless you buy tune with the maf recalibration it would take awhile to dial it in. The Bosch stock will interchange 86-89 although there are different part number. You can't beat the oem quality and reliability .
https://www.thirdgen.org/forums/diy-prom/459352-maf-tpi-analog-ford.html
Old Feb 14, 2015 | 12:00 PM
Engine: Lb9
Transmission: M20
It's hard to say what the failure is. Keeping the wires clean with maf cleaner may extend its life. When I had a 85 iroc the maf failed at 150k.
Old Feb 14, 2015 | 12:03 PM
mackjar66's Avatar
Car: 1989 GTA
I have not seen that thread but I have wondered about going with the Lightning MAF upgrade. I know a lot of builds using that one. Plus I am getting a custom Dyno tune once this is all out together.
Old Feb 14, 2015 | 12:26 PM
Engine: Lb9
Transmission: M20
You should consult with your dyno tuner and get their opinion, see if they even work with obd1 .
http://www.corvetteforum.com/forums/c4-forced-induction-nitrous/1927593-blow-through-maf-new-idea.html
Old Feb 14, 2015 | 01:05 PM
mackjar66's Avatar
Car: 1989 GTA
He does OBD1. I had him tune out the VATS and EGR already to get this car run again after a VATS issue
Logan Bryant
Aug 27, 2015 11:52 AM
NBrehm
Aug 25, 2015 11:49 PM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
