85 iroc no fog lights or headlights
Old Feb 14, 2015 | 07:06 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
engine swap. new headlight switch, parking lights, brake lights, tail and interior lights work. headlights and fog lights do not. headlight switch is getting power. tested red wire and yellow in back of headlight switch both get power.? any suggestions Hi Beam turn signal switch?
Old Feb 17, 2015 | 04:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Making Headway
OK put the headlight switch in the on position.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the 16 AWG tan wire from the dimmer switch.
When you operate the dimmer switch what does the meter on test light do?
Then probe the
16 AWG light green wire from the dimmer switch.
DIMMER SWITCH COLORS
The colors are
yellow for the power input, tan for the lo-beam output, light green for the hi-beam output.
Happy Racing !
We Keep The Air Wrench Shiny So It Looks Good When We Throw It Across The Pit Box
Old Feb 19, 2015 | 09:30 PM
david86camaro's Avatar
Car: 1986 Camaro
Engine: 2.8
Re: 85 iroc no fog lights or headlights
My first thought would be maybe the relay's, I think if I remember right they each have their own, it seams to make sence if you were messing with things in the engine bay.
Old Feb 21, 2015 | 11:23 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Ground wires connected OK on each side of the Upper Radiator Support ??
Maybe they got unscrewed during the engine swap and not re-connected ???
Old Mar 12, 2015 | 02:15 AM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
thanks for the replies. tested the dimmer switch and i was getting no power. swapped it out and problem was solved
jaridjohn
Jul 8, 2024 03:49 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Omega
Aug 10, 2015 12:46 PM
