1988 Camaro won't start.
Old Feb 16, 2015 | 12:11 AM
SSIROC88's Avatar
Car: 1988 IROC-Z Camaro
Engine: 350 5.7
I have a 1988 IROCZ Camaro that wont start.
i have had problems with the fuel pump but i had replaced it about 3 times now but the one i have in it now is working good, but when i go to start it it will just keep trying but nothing happens but if i spray starting fluid in the intake and turn the key it starts right up and stays on and i can drive it but once i turn it off it wont start again unless i spray it. i can hear the fuel pump come on and the relays click but im thinking for some reason its still not getting enough fuel pressure to the intake for some reason. someone please get back with me ASAP it will be greatly appreciated.
Thanks.
Old Feb 17, 2015 | 09:40 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: 1988 Camaro won't start.
basic info (you have already troubleshot this far)
Old Feb 17, 2015 | 09:41 PM
Car: 91 z28
Transmission: 4L60e
Old Feb 17, 2015 | 10:01 PM
SSIROC88's Avatar
Engine: 350 5.7
Yes I have troubleshot through all that my pump comes on fuse is good and so is the relay. But even at one point of having a full tank of gas it still wouldnt start by itself until i used starting fluid and once i did that it would start right up and stay on until i turned it off myself.
Old Feb 18, 2015 | 05:26 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
did you check the fpr?
Old Feb 18, 2015 | 09:58 PM
SSIROC88's Avatar
Engine: 350 5.7
I have replaced all of the following with new parts. The Fuel pump, fuel pump relay, fuel filter, and the fuel pressure regulator. Also have replaced the distributor. So im not sure what could be causing it to not want to start until i use starting fluid just to get it running and driving.
Old Feb 18, 2015 | 10:14 PM
Barlow8869's Avatar
vacuum leak?
Old Feb 18, 2015 | 10:47 PM
SSIROC88's Avatar
Engine: 350 5.7
all hoses are connected besides one on the back left side of the intake its a small one but i have it closed up. could a vacuum leak cause all of this? But even when i push the valve down on the fuel rail it just trickles out and before i had this problem if i did that the gas would shoot about 2ft in the air.
Old Feb 19, 2015 | 02:29 AM
Barlow8869's Avatar
then you need to find out where the pressure going
Old Feb 19, 2015 | 07:11 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Does your 88 have the ninth injector? The ninth injector is used for startup enrichment. This is basically what you are doing when you spray start fluid into the intake to start the car. Your fuel pressure should maintain for a while but not for a long time, this is why your pump primes when you turn the key on. Spray fluid into the engine to get it running then check your fuel pressure with the engine running. If you have good pressure, check the ninth injector wiring to see if it is firing the injector. Search "cold start injector" for more information. HTH!
Attached Thumbnails 1988 Camaro won't start.-1988-20tpi-20ecm-201227165
Old Feb 24, 2015 | 07:09 PM
SSIROC88's Avatar
Engine: 350 5.7
No i dont have the ninth injector on it. But i do remember getting a code 54 Which is low voltage at the fuel pump OR low voltage at the fuel pump relay OR output failure at quad driver module. I haven't had a chance to get my hands on something to test for the voltage though. but could you send a pic on where the ninth injector is located so i can check and make sure i know i don't but still want to eliminate that.
Derick15
Sep 17, 2016 05:28 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Randomtask2
Aug 13, 2015 01:57 AM
