Purple and Blue Connector Help
Car: 87 Camaro Z28
Axle/Gears: 4th Gen 3.42
I just bought a 92 Camaro RS with a 305 TBI 5 Speed it doesn't want to crank over it has some connectors unplugged under the dash wondering if this could be this issue what are they to?
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Purple and Blue Connector Help
EDIT: I think I misremembered and gave the wrong function for the connector, disregard this post :P.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
2 pin connector in first pic looks like it's for a flasher which would not be causing your problem. Not sure what the other connector is for though.
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
1st pic, turn flasher
http://www.austinthirdgen.org/mkport...ithout_T61.jpg
2nd pic, fog lamp switch
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
Does it make any attempt (noise/click) to start? I would start by testing battery. After battery test good, if it attempts to start follow video in post #5. If no attempt to start, (with helper/ during cranking) check for 12v on purple wire on starter (with purple wire disconnected from starter). If purple wire has 12v move on (with it reconnected) to video.
Linson
Sep 21, 2015 01:08 PM
