No Injector Pulse
Old Mar 4, 2015 | 03:49 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
No Injector Pulse
Hey guys I have a 1992 Camaro RS with a 305 that I am currently swapping to TPI from a Carb setup that the previous owner had installed on it.
I have everything wired up and installed but I can not get it to run.
I have checked everything and i have tracked it down to no injector pulse.
Every sensor on the car with the exception of the IAC is new.
It has a new Alternator, starter, battery, fuel pump and sending unit, distributor,wires, plugs, and injectors.
any help from you guys will be greatly appreciated.
Thanks!
Old Mar 4, 2015 | 08:21 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: No Injector Pulse
I believe the ECM/EPROM requires a VATS signal.
This might help = https://www.thirdgen.org/forums/elec...ing-tuned.html
92-Formula
Dec 12, 2015 10:34 PM
327IROC85
Sep 23, 2015 12:11 AM
rubyred88
Sep 17, 2015 02:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
