Engine bay wiring
Old Mar 16, 2015 | 05:17 PM
alexdavis001's Avatar
Car: 1989 camaro
Engine: 383 roller
Transmission: 5-speed
Axle/Gears: posi 373
Engine bay wiring
I'm trying to clean up under the hood after engine swap. Trying to figure out what wires can I cut out and what wires to leave!!!! It's ugly under the hood please reply guys
Old Mar 17, 2015 | 06:33 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Engine bay wiring
What engine did you start with and what engine do you have now?
What gauges are you running?
Do you have a meter and know how to use it?
Old Mar 17, 2015 | 07:06 AM
OrangeBird's Avatar
Car: 1989 Firebird
I'm going to be honest with you .........
You've really only got two options here . Make friends with someone who knows automotive electrical , or learn how to do it yourself . There are likely 50 to 75 (give or take a few) wires running between the engine compartment and the dash / rest of the car (fuel pump & such) and it would be just about impossible to go wire by wire in forum posts as to what stays & what goes . If you understand electric circuits at their basic level well then now you just need to decide what your engine and rest of your car needs , connection wise , to run . Start with circuits like establishing the key on power for the distributor , then establish the starter solenoid to start wire from the ignition switch , and so on . Once you've met the engine's wiring requirements it'll run .
PS If you have not yet found it in a search , the site austinthirdgen.org has all of our car's wiring diagrams which would be a great starting point for this .....
Old Mar 17, 2015 | 09:13 AM
Car: 1989 camaro
Engine: 383 roller
Thinking about cutting all wires coming from the passenger side fender coming from the PCM. Was a v6 now 383 carbed. Running auto meter tach and all factory gauges
Old Mar 17, 2015 | 12:20 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
armybyrd
Dec 5, 2015 09:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
