relay location
Old Mar 16, 2015 | 06:32 PM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
relay location
Ok ive searched tons of threads on this issue and cant find the correct answer. I am looking for the location of the hatch release relay on a 88 gta. I have half the cars interior apart and cant find it. Thanks for any help.
Old Mar 17, 2015 | 06:32 AM
Pocket's Avatar
Car: 91 Trans Am
Re: relay location
Check under the hatch pull down
Old Mar 17, 2015 | 01:59 PM
trocustoms's Avatar
Re: relay location
Update. After two days of trying to diagnose this problem I figured it out !!!!! It appears the Camaros hatch release button relay is in the console, I think everybody knows that one. my 88 gta has it tucked up under the passenger side dash behind the glove box pocket. its hidden up there. search around and youll find it.
My issues was the hatch motor worked fine. the key method worked fine but the button release didn't work, Had 12 volts to the button switch but couldn't find the relay. found relay and that was working properly.
Upon further investigation, for some reason my 88 gta has to have the parking brake on to complete the circuit. mind you this is an automatic and always has been. feeling pretty stupid about this but I applied the parking brake before and it didn't work. this time I pulled up hard on the handle and sure enough it activated the switch and the hatch popped.
Strange because I owned a 90 bird with an automatic and didn't have to use the e brake.
Anyways everything works and hopefully this may help someone else !!!!!
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
Gunsbee
Sep 7, 2015 07:10 PM
tonys91rs
Sep 2, 2015 07:07 PM
