ALDL question (A/B Jumper triggers fan but no data)
Old Mar 18, 2015 | 04:48 AM
zeitghaist's Avatar
Car: 1989 Trans AM
Transmission: TH700R4
Hi,
I'm currently trying to learn more about my car and got myself an ALDL Cable (installed the drivers on my laptop and the connection tests ok in winaldl).
Now according to the instructions there is a jumper with three different settings and I'm most probably doing something wrong since I don't get any data at all...
Setting #1 "Normal":
No data, no reaction (should be this way I think)
Setting #2 "A --> B":
No data
Setting #3 "A --> B with 10k resistor"
No data and motor - fan starts running
Tried it with a paper clip too and only the fan starts running (ses light goes out like normal, not triggering any diagnosis mode) --> Would greatly appreciate any ideas on what I'm doing wrong!!!
PS: The car runs normal apart from two (at least I think not connected) problems --> Rough Idle (I wanted t get the IAC and TPS reading because of this) and my headlight switch is most possibly busted since they go up but not down and the activators and relays test out ok
Old Mar 21, 2015 | 03:25 PM
zeitghaist's Avatar
Car: 1989 Trans AM
Re: ALDL question (A/B Jumper triggers fan but no data)
no ideas?
Old Mar 21, 2015 | 07:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Are you turning the key on?
Old Mar 22, 2015 | 12:00 PM
zeitghaist's Avatar
Car: 1989 Trans AM
I tried it with Ignition and with the motor running, maybe the problem is with my timing, when should I try to connect pins a and b? (before turning the key? or after the security light goes off?)
Old May 9, 2015 | 12:24 AM
BlackBoulder's Avatar
Car: 1986 IROC Z
Engine: 5.3
Transmission: 4l60e
A little late on the post, idk if it matters but when i do the paperclip test i insert it before i turn the key.
Old May 11, 2015 | 07:59 AM
zeitghaist's Avatar
Car: 1989 Trans AM
I got it to work on saturday, don't ask me what the reason was
The right order is:
-Plug in (with resistor if needed)
-Turn the key
-If the fan starts running you triggered the Diagnostics Mode (we want that^^)
-If Winaldl doesn't get any data now check the connection (mine was good enough to trigger the mode but too bad to get data as far as I can tell) and/or correct the config for the right ECM and BAUD Rate!!
--> Success
chazman
Aug 28, 2018 03:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
overdriv
Aug 20, 2015 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
