Tpi crank trigger conversion
Old Apr 16, 2015 | 05:15 AM
Tommy T's Avatar
My plan is to make crank trigger conversion for more accurate ignition timing.
Car is -89 Firebird with 1227165 stock ecm.
What kind of ignition timing pulses can this ecm handle?
(what crank trigger wheel i need to get. Number of teeth/magnets)
Does conversion work like this...
I
Cut wires between ignition module and magnet trigger from inside my msd #8366 distributor.
Remove the trigger and reconnect the
ignition module wires to hall-sensor on a crank pulley?
How to position crank trigger wheel correctly?
Old Apr 16, 2015 | 07:36 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Tpi crank trigger conversion
Welcome to the board!
This is more than crank trigger and re-wire.
Search and research.
https://www.eficonnection.com/eficonnection/24x.aspx
Caspar
Jun 19, 2016 11:19 PM
overdriv
Aug 20, 2015 03:52 PM
Sanjay
Aug 12, 2015 03:41 PM
