Check Engine dash light
Car: '82 Camaro
Engine: 305ci (SUJ) not crossfire
Transmission: TH350
Axle/Gears: Stock
What does it mean? What is the light connected to? Is it important?
How to cancel.
How to cancel.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Bright
The SES illuminates if the ECM detects a problem in the systems it monitors.
Not all of the problems are serious.
For intermittent problems the SES will flash then go out.
To find out why your light went on you can buy a code scanner to plug into the ALDL (Aassembly Line Diagnostic Link) and the scanner will display problems the ECM has knowledge of, as well as give you some engine operating information.
The ALDL is located at the Fuse Block which is located up and to the left of the brake pedal, behind a small door.
Happy Racing !
He Must Have Been Cheating - Because I Was And He Almost Beat Me.
Happy Racing !
