89 Iroc power issues
Old Jun 15, 2015 | 03:45 PM
moneyz1's Avatar
I have a 1989 Iroc z and the dome light, lighter outlet and volume on the radio won't work at all . Also every time I use the car I have to jump it. I haven't had the car on the road in about a year and half but before I took it off the road I put a brand new altenator and battery in it and I always have started it as often as I could and everything was working fine till all this started happening a month ago. The car is now back on the road for the summer and the car is like brand new it has 24,000 original miles on it idk what could possibly be wrong with it I take great care of the car does anyone have any idea what this issue could be?
Old Jul 2, 2015 | 01:40 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Drain Is Insane
Sometimes the under-hood or hatch light does not go out so check those easy ones first.
Then connect an ammeter in series with the battery.
If there is more than 50 milliamps there is excessive draw.
(You can use a small bulb such as a side marker bulb if you don’t have an ammeter.)
Disconnect the alternator wires to see if IT’S the problem.
With everything turned off and doors closed observe the current flow.
Pull the fuses one at a time, including the pump fuse near the battery, till you see the current drop.
That’s the circuit with the problem.
Happy Racing !
He Must Have Been Cheating - Because I Was And He Almost Beat Me.
87 camaro iroc
Jun 24, 2016 06:06 PM
armybyrd
Dec 5, 2015 09:22 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
