Radio will not turn on (Clock works but nothing else)
Old Jun 22, 2015 | 02:41 PM
Glowsock's Avatar
Car: 1989 Firebird
Engine: 305 TBI
Hello, wondering if anyone could help me with this, the clock always works, turning on the radio used to work but now pressing the power button simply does nothing. I checked that all wires are properly plugged in on the back of the radio, should I pull it out and check wires with multimeter?
Old Jun 23, 2015 | 10:50 AM
Glowsock's Avatar
Car: 1989 Firebird
Engine: 305 TBI
Re: Radio will not turn on (Clock works but nothing else)
Is it possible that its just the radio it's self? Im wanting to buy a deck along with an amp and subs but I want to eliminate this problem first because I dont wsnt to be wasting money if it wont work
Old Jun 29, 2015 | 07:07 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Radio-active
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) find which wire has no power.
If it’s the
orange wire the problem is the ARC fuse, or associated wiring.
If it’s the
yellow wire the problem is the RADIO fuse, or associated wiring.
If you find power on those wires then it’s probably time for that upgrade.
Happy Racing !
The Steering Turns Real Easy When The Car Is On The Roof
Old Feb 14, 2019 | 07:25 PM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
I know this is an old thread but it’s the exact same issue I’m having. Did you ever figure it out?
Old Feb 15, 2019 | 12:42 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Clock runs on ORANGE, Radio runs on YELLOW. Check the YELLOW for voltage and check for good ground ( BLACK wire).
Old Feb 15, 2019 | 04:34 AM
doing this on my bench tester so power ground and such are all good
Old Feb 15, 2019 | 11:58 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Radio toast!
Hit up the parts yards for a Delco am/fm/cd with equalizer! Usually less than $100
Or get what aftermarket stuff u like!
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
ZsTransAm
Aug 11, 2015 07:30 PM
