Help! Wiring assistance needed!
Old Jul 23, 2015 | 08:16 PM
ShadowsX42's Avatar
First post, long time stalker! I recently picked up an 89 Z28 I believe to be a 305 TBI. It was sitting for a while but fired right up and made the 12 minute drive home. It suffers from the dreaded single electric fan not working unless the A/C is on!! I replaced the CTS and thermostat, can't get to the sender on the passenger head yet. I've decided to wire the fan to a toggle switch and came upon this mess. First, can I get opinions on how to repair it? And secondly, is there a diagram I can follow for the toggle switch? I've read through sooo many other topics like this but I think I got overwhelmed. Any opinions are appreciated!!!
Attached Thumbnails Help! Wiring assistance needed!-wp_ss_20150721_0006.png   Help! Wiring assistance needed!-wp_ss_20150723_0013.png   Help! Wiring assistance needed!-wp_ss_20150723_0015.png   Help! Wiring assistance needed!-wp_ss_20150723_0014.png   Help! Wiring assistance needed!-wp_ss_20150723_0016.png
Old Jul 23, 2015 | 08:57 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Help! Wiring assistance needed!
Here is a coolant temp switch diagram from Austinthirdgen. Just run a wire from the black wire on the relay to your toggle switch then to a good ground. The switch and wiring will be protected by the fuse and will ground the relay to energize it just like the coolant temp switch would do. HTH!
Old Jul 24, 2015 | 06:00 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Its not actually a 'problem' (with OE wiring) though, you do have a mess. TBI fans are only controlled by the fan switch (on at 238°F) or, by the hvac controls set to an a/c position (a/c does not need to work for fan to run)
Old Jul 24, 2015 | 06:41 PM
ShadowsX42's Avatar
Thank you! Fan is hooked up to a toggle switch for now. It will be done right eventually. I connected that green wire back together and the green/white back together. But the loose red one worries me. Do we happen to know what colors are supposed to be where??
Old Jul 24, 2015 | 07:08 PM
deadbird's Avatar
Engine: TPI 305/ v6
This is for 92 tbi, 89 will be the same.
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
armybyrd
Dec 5, 2015 09:22 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
