From the fuse block
Car: The Car-1990 Camaro RS Coupe
Engine: 5.0 Litre
Transmission: standard
Axle/Gears: single axle 5 speed
From the fuse block
When I look on the back of the fuse block there is one wire instead of two going to the fuse area for "gauges fuse". Is this normal? Does the fuse box itself carry the power to this fuse so the wire out is going to the wire harness for gauge cluster? Some of the backs had two wires. For instance the "INST LPS" (instrument lamps). I was able to use in-line fuse between its two wire to take care of problem at fuse block (broken fuse holder). With one wire I'm not sure what to do, as I cannot join the "two wires" with an inline fuse between because there are not two wires. Thank you.
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: From the fuse block
The pics are kind of fuzzy, but yes it is possible that a circuit feeds more than one fuse. You'll see that some of the wires in your pics have bus bars connecting multiple terminals. If this is not what you're talking about, please provide photos and highlight the specific terminals you are asking about.
Dalton1989
Jan 19, 2016 11:10 AM
89GTASC
Nov 11, 2015 09:22 PM
