Ignition Issues
Car: 1982 Pontiac Firebird
Engine: 2.8L V6(upcoming 350 Swap)
Transmission: "World Class" T5
Ignition Issues
I have a 1982 Firebird with a good starter, good battery and the engine has been cranked and started in the last couple weeks but it was an inconsistency of starting. Sometimes it would start right up and sometimes when i turned the key the starter wouldn't even click. Now it wont start at all. Please help
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Ignition Issues
Check the purple wire on the starter solenoid for voltage when the key is turned to start. Should get 12 volts. If not, go to the clutch switch and check for voltage at the yellow wire. Again, should have 12 volts when key in start position. If not, yellow wire goes back to ignition switch, check it there. HTH!
Re: Ignition Issues
ok i was thinking it had something to do with the clutch switch. just didnt know for sure. thank you!
