no power. battery is ok. fuse links?
Old Nov 20, 2015 | 08:08 PM
Tas's Avatar
Tas
I've had fusible links blow on my jeep before and this seems the same. I turn the key and have nothing. there is no power to any lights. nothing. Where should I start looking?
Old Nov 20, 2015 | 08:15 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: no power. battery is ok. fuse links?
If battery is okay, I'd check positive cables and ground. Work your way out from there. Nothing to the fuse box?
Old Nov 21, 2015 | 10:19 AM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Power to entire car comes through pins A4 and G5 on the c100 bulkhead connector at the drivers side of the firewall. Those two get there power from the starter positive battery terminal and there are fusible links in he circuit too, located right after the connector on the starter. I had this happen to me before and I hate the way the factory did this. I am I the midst of redoing my old TPI harness to eliminate fusible links and overall better power distribution while running most of the power circuits in the engine bay through a fuse/relay center
Old Nov 25, 2015 | 08:55 AM
Pocket's Avatar
Car: 91 Trans Am
Fusible links are on the starter. The link is the actual wire, not the white cyls. No power on the lights or fuseblock points to band fusible links or simply not connected to the battery
LarryD
Dec 10, 2015 02:33 PM
BobKnake
Nov 24, 2015 07:36 AM
cheezus
Nov 21, 2015 09:17 AM
SHELL929
Nov 18, 2015 01:51 PM
92firebirdguy
Nov 17, 2015 05:31 PM
