dome light and radio are not working
Car: 1988 Camaro RS
Engine: 2.8L v6
Transmission: 700r4 stock?
Axle/Gears: peg leg one tire fire
made some progress on the radio harness today. I now connected the radio harness to the stock wiring with wire nuts. all connections are good. My radio power button will light up, but when the power button is pressed, nothing happens, it doesnt turn on. I would guess it was the radio, but now the dome lights arent working either. They were working fine previously before the new wiring began. Checked all the fuses and none are blown or missing. any help? thanks in advance!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Radio Active
Is it the stock radio?
(More info is needed to diagnose.)
Dome Light:
Check for power on both sides of the ACC FUSE.
Is there power?
If yes, remove that fuse and Dome Bulb, then use an ohmmeter to trace the orange wire from the fuse output to the dome light.
Is there continuity?
If yes, open both doors and turn the dome light switch to the ON position.
Use the ohmmeter and connect one probe to ground.
Connect the other probe to the other contact White wire on the Bulb Socket.
Happy Racing !
I’ll Bump You Once To Move You Over, Next Time I’ll Spin You
Dome Light:
Is there power?
Happy Racing !
knightinblackar
Interior Parts Wanted
Dec 4, 2015 12:40 PM
