wiring for hatch release
Old Dec 8, 2015 | 11:59 AM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Axle/Gears: 373 posi
I am trying to get my hatch to latch and I can't find any wiring diagrams. I do not have a manual so I can't tell which fuse it might be either. Ant help would be greatly appreciated.
TIA
Geoff
Old Dec 8, 2015 | 12:39 PM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Re: wiring for hatch release
This is a picture of the wiring at the latch. Note the unattached blue wire and the red/white power wire with the female plug on the end. Are these to supposed to connect?
Old Dec 8, 2015 | 01:14 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
See this: hatch (1).pdf
https://www.thirdgen.org/forums/inte...pulldown+motor
Old Dec 9, 2015 | 09:21 AM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Thanks Bob, for pointing me in the right direction. I reset the latch switch and now it goes up and down but cannot be activated remotely. I am assuming my switch is bad, even plugged in another used one, still no go. Is there a way to tell with a multimeter if the switch is bad or not?
Old Dec 9, 2015 | 09:48 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You can test the switch for continuity. Check the wiring from switch to the motor. And power to switch.
Old Dec 9, 2015 | 11:53 AM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
I have no power to the switch. There is a separate circuit for the hatch release solenoid, isn't there? Where would the fuse for that be?
Old Dec 9, 2015 | 12:39 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
look at the 2nd page of that hatch wire diagram from above that I included in post 3.
Power comes from the ACC fuse in the fuse panel. You also have a relay involved.
Ed1LE
Jan 21, 2016 01:48 PM
mustangman65_79
Dec 15, 2015 04:18 PM
claw87
Dec 11, 2015 07:45 PM
86CamaroDan
Dec 7, 2015 10:09 AM
madness
Convertibles
Dec 4, 2015 11:49 AM
