NEED HELP! Factory Tach WAY off since MSD box installed.
Old Dec 21, 2001 | 11:12 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Does anyone know a fix until I get my autometer Lunar series tach? The box is a MSD 6a.
Old Dec 21, 2001 | 02:06 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
From what I understand there's a filter somewhere inline on the tach wire from the coil that has to be bypassed to keep the factory tach from going screwy.
Old Dec 21, 2001 | 02:23 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
My fix for this was to cut the tach wire (white wire on connector with fat red wire) and run it directly off the MSD box. Works great.
Old Dec 21, 2001 | 05:42 PM
MidnightZ's Avatar
I also have had a problem with my tachometer. I have run the car with and without the inline tach filter, and also purchased the tach filter from MSD. None of this has fixed my problem. Still wondering what I should do about it.
Old Dec 26, 2001 | 09:55 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You cut the white wire only, right? Also, where did you cut it? At the coil or behind the instrument cluster? Thanks guys, keep 'em coming. All info is appreciated!
Old Dec 26, 2001 | 10:28 AM
MSD tech's Avatar
There is a tach filter in line. The filter is normally with in 1-11/2 feet of the coil and will look like a Small black cube. By pass this and reconnect the wire and the tach will then read correctly.
Old Dec 26, 2001 | 02:25 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
By bipassing the factory tach filter, will this cause damage to the factory tach and or instrument cluster? What is its function? Also, when I wire up the Autometer tach, I will run it to the box. Do I need to put a filter between the new autometer tach an the MSD box?
Old Dec 26, 2001 | 02:54 PM
MSD tech's Avatar
What the filter does is eliminate spikes that occur off of the factory ignition. With the box in place this no longer happens and the filter can be bypassed. The Autometer will not require it either. Regardless no damage will occur with the filter out, if you ran it on the stock ignition with out it the only thing that would happen is you would probably get some jumping out of the tach.
Thanks,
Joe
Old Dec 27, 2001 | 10:10 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thanks Joe!!
9192camaro
16
Feb 3, 2019 12:21 AM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
mx127
Aug 10, 2015 08:13 AM
stalkier
Aug 7, 2015 04:49 AM
