CAN SOMEONE IDENTIFY THIS PLUG??
Old Dec 27, 2015 | 07:04 PM
GBRONNE's Avatar
Hi guys and girls new to the forum, just picked up a 91 rs 305 tbi, the previous owner had a hack job alarm installed, i had removed all of its components, during that time i came across a t-tap splice from the red of the headlight switch through a circuit breaker, out the firewall t-tapped on to the heavy red wire of this plug. I had removed that jumper and lost headlights, parking lights, horn, dome, etc. could anyone identify this connector? specifically what its plugged in to? there is nothing behind the female side, looks like power goes in and back out. i tested the pins for continuity in the socket side and they're all open to each other. this plug and socket is under the hood, just next to the brake booster, i can simply just put the jumper back but i'd like to resolve the original problem, any help would be great! thank you in advance. Gary.
Old Dec 27, 2015 | 07:06 PM
GBRONNE's Avatar
Re: CAN SOMEONE IDENTIFY THIS PLUG??
this plug
Old Dec 27, 2015 | 07:37 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
FP relay
Old Dec 31, 2015 | 06:33 PM
Pocket's Avatar
Car: 91 Trans Am
Its a relay of some sort for sure. Need to know what wires go to it (colors) to properly ID
Aviator80
Dec 18, 2015 06:25 PM
SteelheadBen
Dec 15, 2015 04:11 PM
jorgeblancojr
Dec 11, 2015 11:33 PM
sactown
Dec 10, 2015 08:44 PM
FiVe KiLLZ
Dec 9, 2015 07:40 PM
