radio faceplate change?
Old Mar 8, 2016 | 11:44 PM
nater's Avatar
Car: 1984 camaro berlinetta
Engine: v8
ok so i have a 84 berlinetta with the stock pedistal radio. i realy like the way the stock radio looks with the rest of the car, but of course the right chanel glitches out and the left one sometimes too. i am not sure the radio is salvageable as the base has a lot of corosion in wierd colors. but the faceplate(pod) appears to be fine. what im wondering is can i use the wiring from the pod to control a diferent radios internals. for example using a stock gm(or other?) radio from a diferent car for the internals and my pod for controls, or even beter a well chosen aftermarket radio for the internals?
also if i can get it working what is the best way to run outputs from it to an amp for a sub without using rcas, my amp has built in line converter?
so far ive pulled the internals ive had apart 3 times and resoldered diferent things but it only works for a short time before cutting out again.
BlueZee28
May 27, 2016 07:19 PM
Digs_do_it89
Apr 11, 2016 12:26 AM
pfsteichen
Convertibles
Mar 24, 2016 09:05 AM
BlueZee28
Exterior Parts for Sale
Feb 29, 2016 07:43 PM
redwolf7374
Feb 22, 2016 07:42 PM
