3RD brake light...
Old Dec 23, 2001 | 10:30 PM
XxMoLexX's Avatar
3RD brake light...
ok i have yet to see a late 3rd gen camaro that actually has one that works... im guessin its a piece o crap part...
anyways.. even with new bulb... i cant get th bulb to light up... im leaning towards the fact that the bulb doesnt stay in there... and never feels as if its "locked" in...
anyone else realize theirs doesnt work and fix it?... i think that its jus the connection that is bad... which would explain y it doesnt click in and hold the bulb... im no electrician by any means.. but i understand the basics...
suggestions on how to fix it?
thanks fellas... and ladies.. althou i havent seen many of em..
Happy Holidays...
Old Dec 23, 2001 | 11:27 PM
Drew's Avatar
I don't know, burned out 3rd brake light bulbs are a pet peeve of mine... any burned out bulbs are... I mean come on, everyone can afford a bulb and should be able to install them.
Since you have a 91, I'm assuming thats the brake light you're working with. From the start you're further ahead than the 87-90 camaros with the 5 halogen bulbs that cost a minifortune each. The 91-92 cars have a single bulb thats available almost anywhere.
Now for the problem. You've got a trim cover, a reflector/bulb socket assembly, and a red lense. What I found was on my formula it was a simple unplug, plug in new bulb, reassemble. My other 91 Firebird was a pig. When GM assembled the reflector/bulb socket assembly they glued the brass contacts and wiring into the ABS socket. Well before the glue was dry some genious plugged in the bulb. So here I was 10 years later with a burned out bulb that was glued to the socket. When I pulled it out the reflector/socket assembly turned into about 4 seperate pieces. They each had to be seperated from the bulb, then I had to reglue the reflector/socket assembly, and then after everything was dry I installed the bulb and it worked fine.
So, what I'd suggest, check the bulb socket and make sure its not cracked. If it is, glue the cracks with epoxy or something similar and try it again. If it still doesnt work make sure the contacts are clean, then if the problem continues start checking wiring.
Old Dec 24, 2001 | 03:56 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I commonly find the bulb is not making good contact with the socket. Very carefully bend the contact points on the bulb slightly outwards. Then push the bulb back in and try again.
Old Dec 24, 2001 | 04:16 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You may also want to verify that you have voltage at the socket when the brake padal is depressed. The high mount brake light is on a separate circuit from the lower two brake lights, for redundancy, so part of your brake light switch may be defective.
Old Dec 24, 2001 | 08:20 PM
XxMoLexX's Avatar
Thanks fellas... ill see wat i can do...
happy holidays
Old Dec 26, 2001 | 10:25 PM
un4givin89's Avatar
Must mean the 3rd brake lights on the rear glass, cuase I never had a problem with mine on my spolier.
Old Dec 27, 2001 | 03:38 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
my problem was the black coily cord was bad, I replaced the wire and that lasted 2 weeks and it stopped working again. Finally I just bought a new GM 3rd brake light assembly (over $100)!!! Works fine now!
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
